Hey all,
I've got an 85 GN with a new GN crate motor. The motor has been checked out, lubed, and gone through cam break in by a local reputable shop. I installed the motor and trans and assembled all parts above the "long block" myself.
While the car was parked before the new motor was installed I added: 87 ecm with a translator chip, LT1 maf, MAF Translator, Big Mouth cold air intake, fuel pump hot wire, Walbro fuel pump, green strip injectors, adjustable fuel pump,heated O2 senser, and a used fuel injector harness.
The fuel rail, valve covers,pipes, and other parts where sandblasted and powder coated. Other parts like the throttle body and intake were blasted and painted. Items like the throttle body were totally dissassembled before plasting and painting.
Problem: the car runs great from cold. Once it gets up to temp for a long time, or the car is at temp and you shut it off and restart, it runs rough. The car runs like a cylinder is dead. For lack of better words... it's a putt, putt, putt kind of sound. This seams to die down at around 40 mph.
A check of the spark plugs showed that the #2 cylinder was much cleaner than all the other plugs. #4 cylinder was mid-way between all other cylinders.
I have changed to new plugs, wires, ignition module, and coil pack. None of these changed the issue. I've ruled out the ignition system as a problem. The crank and cam sensors were new with the crate motor.
Sorry for the long post... Any Ideas???
Thanks,
Tim
Thanks,
Tim
