Usually a launch from 4200-4800 is sufficient for great 60 foot times.
I agree with you,iwill send it to you to tightin up on bottom.
I'd be looking at your wastegate arrangement 1st. You should have no issues with getting more boost at that rpm level.
Are you using a boost controller to hold the gate closed at launch? On the Stage 2 car with an 88 that I tune locally we have no issues getting enough boost for 1.32-1.34 60's on a 275/60 radial by leaving at 4800 rpm and it only drops 1000 at the gear change so it's actually looser than yours.
Do you have rpm data to compare this PTC to the old converter? I'm guessing you need to be looser rather than tighter.
You definately need to be looser at the gear change.
unfortunatly i got my laptop steal and lost every data.Looser a bit on top and tighter on bottom.What do you think?
I think it just needs loosening 400-600 everywhere.
I would have wanted to see how rpm/boost compared to the old set-up. Tigtening it up down low will only slow down the spool-up.
You really think I should loosening on bottom ? I have no problem to spool and dont have stages limiter.
Tightening the bottom can possibly build more boost at a given rpm but looser will let the rpm flash higher at the release of the transbrake. This extra rpm allows the boost to come in quicker without hitting the tires too hard. Generally you can build as much launch boost as you need with a loose converter and bring the boost in quicker without worry about wheelspin. I've never had anyone who's 60 foot times were slower because the converter was too loose. It's usually the boost controller needs some tuning to optimise the power.
Ok Dusty I will change my i/c for much bigger and rise boost and let see what happen.what can i do with my boost controller?
How fast do you have the boost coming in? Launching at 15psi should get you a better 60' than 1.40's. We can leave at 10psi at 4600 and go 1.34 with a converter looser than yours with a 88mm.
How long does it take to ramp from 15psi to 23-24psi.
