GNX stall convertor?
As far as I know, the converter was no different than any other '87 Turbo Regal. ASC performed some transmission recalibration but didn't remove the transmissions during the conversion.
You are correct....same converter.....the valve body was reworked but the trans was never removed.... all work was done with the pan removed.
thank you guys, so basically the trannie had a few tricks done to it but there was nothing special with the D5 convertor that was used..
