I have a bunch of parts that are getting cleared out:
87 GN Seats, almost mint,full set:$600 sold
87 T Type Center caps: $35 each
Stock Radio with 5 band Equilizer: $75
Stock Radio: $50
Modded ECM:$250
87 T Type Center Caps:$35 each
Trick Flow 120# Injectors (2 spare):$100
Wastegate solenoids (3 left):$20 each
Escutcheons:$25 each
Powermaster core:$100
Powermaster pedal:$10
Oil slingers:$5
20 bolt oil pan:$50
Turbo hood ornament:$50
Chime boxes:$8
EGR solenoids:$8
Chrome EGR cover:$8
87 GN Steering wheel core:$35
87 T grey rear carpet inserts:$20 pair
Hot air oil fill tube:$5
New GM Coolent reseviours:$35
Coolant reseviour caps:$5
Passenger under dash covers:$15
Drivers A pillar grey stock trim:$25
Dash surrounds 84+87 GN:$25
NEW oil pump repair kit:$10
6 pushrods 2 DOT, one polished:$20
New rod bearings 20 under:$10
Chrome bumperettes:$10
New Baer brakes for Ford 9":$500
3rd brake light 87 GN:$30
1/8" Valve cover spacers:$15
Chrome wiper arm set:$25
Dust/Inspection cover:$35
Seatbelt actuators:$6 each
Stock Balancer:$45
Battery hold down bracket:$10
Stock rocker arms:$5
Floor shifter:$35
IC brackets:$20 each
Used knock sensors:$5
KYB Rear Shocks (used three months): $50
Black Wiper Arm Set: $40
Drip rail (Passenger side, black)(2) $10
A pillar Trim (Black, drivers side riser) $10
Rear window trim (black, drivers side riser) $10
Chrome Key Lock set (dors, trunk) $10
Lighted Vanity Sunvisors (need covered, unsure if the lights work) $20 FOR BOTH
Stock Radio: $50
Modded ECM:$250
Oil slingers:$5
20 bolt oil pan:$50
Chime boxes:$8
EGR solenoids:$8
Chrome EGR cover:$8
Stock Balancer:$45
Floor shifter:$35
