Anyone?
I'm going to use the stock 2 bar GM map sensor. I have to input the gain and off set values in the XFI to make it read correctly.Did I misunderstand which MAP sensor you want to use?
RemoveBeforeFlight
Thank you. Will those settings read in inches of vacuum or pressure?2bar Map sensor:
Sensor Gain: -12 Sensor Offset: 30 Sensor High: 30 Sensor Low: 0 Decimal Places: 0
my contribution for the week.
Yes I know, I was curious as to Adrians settings since he didnt say how it read and they were different from yours.The values I texted you last Monday were to display vacuum in inHG. It will actually display pressure in negative inHG. Like I texted you earlier, if you want it to display the pressure in psi, then it will display the vacuum as negative psi.
Lol. Thanks again Cal.The gain and offset are the same. What I gave you will just display one more decimal place. I could be mistaken, but I think Adrian got his values from me also
Actually the numbers you listed were different from Cal's. The Gain and Off-Set values are reversed.Hey Guys, sorry for the response,
Yes the numbers I listed were originally from Cal Hartline. They are in InHg and like Cal said, InHg are positive values.
I run a LT1 pump and I see 2 InHg of vacuum when the pump is on, and it stays stable when it is on.
I activated it with one of my Aux outputs and that's it.
I am logging from the passenger side valve cover and pulling from the drivers side.
I never really took the time to tweak the sensor so it is perfect, but it is on my list of things to do over time, but to me honestly it only needed to give me a relative reading and I can see if I am getting major blow-by.
I will say that I ran the car once with the pump on and once without and the log did show that without the pump I was getting more crankcase pressure.
A
