turbo96max
- Jun 6, 2007
Guys,
I just embarked on an extensive project in order to prep for a tune and hopes of adding bigger tire and better traction.
I took some pics and learned a lot throughout the process using a little bit of different peoples products.
If anyone can use pics or info on anything let me know
My initial findings:
Gbodys frame notch kit: somewhat of overkill but great if you are really picky
the material is thick , to me it was thicker than .25 inch , looked more like 3/8
If lowered the additional crossbar support will not really work if welded where the instructions say , since the lowered car will cause the upper control arms to hit the bar. I had to cut it out, weld more plating, cut and grind the car to push it up another inch, still have limited travel now, im going to get aftermarket adjustable ones with heimjoints which are thinner vs the oem box style which should clear the bar. Had i known this I would have purchased them and put them in at the same time. Another option is to notch the factory ones and box them for more support etc
My welder says its like a tank now back there w all that thick plate added
Fbody (ls1 98 ) rear conversion: I used Flynbies ebrake cables : found them to work ,but were short, didnt allow for much travel on the pulling action , only got about 1 inch of cable travel. dont think that is best, 2 inches would be more ideal, but they work, car doesnt move in neutral ,
flynbie new hard lines : worked good, were right in the neighborhood where they needed to be to bolt to the calipers
Disc prop valve: regular brass valve summit offers for gbodys, so far working well with the monte carlo vac master cylinder
Hellwig bar: had to angle it to help clear the rear end cover , should work fine just not perfectly parallel to the ground. input welcome
