Hey guys! Was out driving yesterday and started noticing every time I would step into it, it would seem to bog or would not respond at all. Started going thru the scan master and my volts were dropping fast. 5 min from home and she gave out. Well long story short when I got home checked to see if the volt bulb was bad, but it was not blown so I removed the panel to make sure the socket was making a good connection. It seemed ok, so I put everything back together and turn the key and noticed something was burning, took the panel off again and it was a wire sandwiched inside the plastic that covers the back panel. So now my question, is there replacement for that? Wish I knew what it is called but hopefully you guys can help me out. Thanks!!
