I am installing a new set of Autometer Ultra Lite 2 gauges. My question is regarding hooking up the voltmeter. Has anyone used the power and ground that you used for the lighting on the voltmeter? Im trying to simplify my wiring a little bit and figured the LEDs in the gauges wouldnt use much. Can i use the same wiring for the lighting to power the voltmeter or should i use a separate power and ground for it?
Thanks!
Thanks!
