Sumbeach86gn
- Aug 2, 2014
I'm going through my 86 gn. It's been sitting for seven years. Along with spring cleaning I pulled the radiator, ic, and gas tank to clean and flush. My thoughts are.... Put on a duttweiler neck while the ic is out. Also upgrade the fuel pump while tank is off. Was liking what everyone says about the 340 with hot wire combo. The rest of car is still stock. Will a pump upgrade work ok with stock injectors, chip etc. I'm planning on a scan master for tuning and maybe pressure reg too. But I can only buy so much at once. The plan is to get her running again then do other mods one at a time, like injectors, chip, air intake etc.
