86 got boost
- Mar 17, 2005
its w/ one wire at the rear of tank, 3 pin female connector for fuel pump/sender its tan w/ white tracer- oil sending unit wire? mine has been removed (still in harness an corroded wasn't covered from moisture) and replaced w/ a wire that runs to positive side of external bosch canister pump, (which Im removing, an putting new pump back in tank)... the other wire on positive side runs to the fuel pump relay... looks to be a faded yellow wire.
Could I solder these two together? an run that way?
cause this wiring diagram I have does NOT show a yellow or a tan, there is a gray wire on diagram that the tan/white wire connects some were in haness.... still have to run my hotwire too...
