turboTchris
- Apr 20, 2012
i just got a new walborol pump sender and waiting on the relay. i drove home with a 25"fuse in the ij/pump and the car ran good but air/fuel readings were all over ex. acceleration in the green 130 give or take then wile braking the readings go into 150/160/177/then i blow a fuse so the next day i put a new fuse and it was fine for about 2min. then blown fuse again, lastly replaces fuse and i blew the fuse soon as i turned the key no the car won't run at all I'm wondering is it the relay ,pump,or the sender or could it be i need a new MAF with a translater? could one of y'all give me a direction to go into.i mean i just got close to 7000grand of work done on the car and all that is sorted it rally need some work plus i got 60lb injectors would that effect it? thanks guys\can't even take er out on a nice run on sunday mornings
