I recently blew the 30amp relay that bolts under the back bumper for the fuel pump hotwire kit. I thought the Walboro pump had gone bad, but everything was fine once I switched back over to the stock plug at the tank. I wanted to let everyone know that a BWD R3111 Relay is an exact replacement. I went ahead and ordered the Racetronix kit because it looks like it has a better seal on the wiring at the relay. If you have this older hotwire kit, similar to the Caspers kit, then this relay is a good replacement if needed. If the previous owner had installed it on the tank mounting bolt, instead of on the bottom of the bumper support with the wires facing the tires, this relay would have survived the rainstorm I had to drive home in.
