1984grandnat
- Oct 28, 2001
I've been having some problems with fuel pressure lately, and need a little assistance. Here is my fuel system setup: Walbro pump with hotwire kit (less than a year old), Accufab adjustable fuel pressure regulator (a little over a year old), 50 lb injectors from Kenne Bell, and a Kenne Bell hood-mount pressure gauge. Here is what happens: when I first turn the key on, the pump runs for about 3 seconds (which is normal). During this few seconds, fuel pressure is at about 35 psi. As soon as the pump shuts off, pressure drops to about 30 psi. After I start the engine (and the pump comes back on), fuel pressure goes back up to 35. When I step on the gas, fuel pressure DROPS from 35 to 32 or so (instead of going UP). When I let off the gas, the pressure levels off at 35. While driving the car, the fuel pressure does not fluctuate much, even when in boost. I have tried following the "Fuel System Check Up" as posted at Gnttype.org, but this does not tell me much, and doesn't really seem to apply to my specific problem. The drivability is pretty poor, and the car sputters when boost rises above about 7 or 8 psi (running lean, I am guessing). Any ideas?
