B Blkt6 Member Joined Aug 29, 2001 Mar 26, 2003 #1 Retuning my car what fuel pressure with line off for 009(42.5lb) injectors and a TE44. Thanks, Paul
T TURBOV6 "SECRET PARTS" Staff member Joined May 28, 2001 Mar 26, 2003 #2 I would use a scantool and slowly up the fuel until you get around 128 (BLMs). I have around 48lbs of fuel (line off). 009's like plenty of fuel. If your BLMs are high then you might have a bad PCV or a vacume leak
R Roger Active Member Joined Jun 1, 2001 Mar 26, 2003 #3 48 lbs with extender chip & no knock at 16 lbs boost. picked up 2 more days on a tank of gas from Reds chip & 45 lbs.
