THere are repair sections available from NAPA and most other parts stores with the proper Saginaw fittings already sweged on. You will have to do some tight bending to it, but it is doable. THey come with compression fittings to splice them in. This is if you do not want to replace the complete line. Be careful, as a fuel leak at 60psi near the exhaust is real bad Karma.
