Hey folks. I believe I'm going to have to replace my fuel level float and sender. I just don't trust my fuel guage as it seems way too inaccurate. Any specific brands or vendors that you recommend or that I should stay away from?
Johnnie
Before you go through trial and error, use an Ohm meter to check the sender. Full should be 90 Ohms, empty zero Ohms. You can drop the tank, fill it and then test the sender in while the tank is out of the car. A full tank is 17 gallons.
