Donniejr81
- Jun 20, 2008
Ok here's what I've done. I swapped the drivetrain from an 85GN into an 85 NA Regal. I swapped the engine harness, dash harness, ECM, instrument panel, as well as engine, tranny, etc.
Now the problem. The injectors will not fire. The car will fire right up and run smooth for a few seconds if you pour a little gas in the TB though.
I have checked cam and crank position sensor voltage, all of the grounds underhood as well as at the ECM (visually and voltmeter), even getting voltage at the injectors, and that all jived.
The two problems I found are the TPS voltage is WAY low (.004-.008) the wires to it have voltage but lose it as soon as you plug the TPS in. Next the injectors have 12.5V and drop to 9 or so when cranking. I can manually ground the injector and it will fire. Can the TPS be causing my injectors to not fire or am I dealing with two separate problems?
