Seen a couple people on the forum with the same problem but nobody really giving an answer . Recently went to get gas filled up the tank. Gas gauge only read half tank. After driving car a couple miles gas gauge did go to full. Next time I went to start the car gas gauge only read half tank again. Drop the tank replaced the entire fuel sending unit along with fuel pump. Also installed hot wire kit. When done started car up gas gauge read empty. Went to gas station filled up gas guage once again reads half tank. While driving home gas gauge goes to full. Obviously the sending unit wasn't bad it must be something else any ideas? I did pull the dash cluster out and checked the terminals where the cluster plugs in at reassembled with a little electric grease. Still reads half tank.
