84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
Hello,
So the machine shop called me Friday and asked to see the camshaft (to check the bearing clearances of the new installed King Bearings). I see that TAPerformance has some really nice grooved cam bearings, but I had already bought the Kings from FTS. So I drive over with the cam and the machinist takes one look at my cam and calls the shop supervisor over. They, both proceed to tell me that the little wear step on the top of three of the lobes is not acceptable and I should buy a new cam and lifters as you should never match a new cam to existing lifters. Not even roller lifters? The step on the top of the lobes "feels like .001" the machinist tells me, all the lobes clearly show the path of the wheel riding up and down the cam lobes.
I was really not expecting this, on top of everything else that I just purchased. Crank, flex plate, balancer, new valves, push rods, bearings, rings....
Question for the engine builders, what method do you guys use to check the installed spring height? I'm thinking perhaps the springs are close to binding, causing excess wear?
I see that ebay has several different spring micrometers for sale, do I need to get the "beehive" mic?
Chuck
Chuck
