C carguy Member Joined Oct 18, 2005 Sep 20, 2017 #1 What's the tallest 15 in tire i can put on front without rubbing?
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Sep 20, 2017 #4 Probably 215/70/15 they are 26.85" in height where your stock tire size is 26.00" in height...and 235/70/17 are 27.95" in height. Also just curious why you want a taller tire on the front .. Good Luck..
C carguy Member Joined Oct 18, 2005 Sep 21, 2017 #5 I have 275 60 15 MT street slicks just trying to lift the front a little.
T The Granny Active Member Joined Sep 30, 2015 Sep 21, 2017 #6 go to a discount tire and have them test fit the tire for you. if you buy them from them they'll test fit it to be sure Sent from my iPhone using Tapatalk
