Ok guys, made it out this weekend for a few runs, and tried running with the driver's side swaybar link completely disconnected. First thing I noticed, needed to run about 25 lbs in RR airbag on a 0-2 psi launch, seemed to have good weight transfer(previously with bar fully connected have not needed more than maybe 5 psi). Tried a 4-5 psi launch, initially hooked and then tire shudder about 10 ft out--guessing it wanted more air in airbag. Question is, if I also disconnect passenger side front link will I get more even weight transfer so I don't have to run such high pressure in the bag?
