While playing around and checking everything with my new silverline Mityvac I noticed when I applied vaccum to the FPR port that it would start going down at a good rate as soon as I appllied it. I tried going straight to the barb fitting on the regulator and same thing. It is not that old and a Accufab. Should it not hold vaccum? Blown diaphram or something? I would think that would definately cause some lean conditions although at 25-26lbs with 50lb injectors and only 39 base line off the Scanmaster never goes below 7.85 O2 volt. Any thoughts guys. Thanks for the input in advance.
