Found a GN...
jake616
I found me a GN and the owner said he would get back to me on a price. Can somebody please run the VIN # for me and tell em what comes up? I don't want it to be a clone, or wrecked.
1G4GJ1172HP460448
Thanks!
jake
Can't help you with the VIN and Carfax but if you make a new post with the Title Carfax help needed and then post the information you might get help quicker.
Good luck, seems like a later build car which could be nice. :)
YOU FOUND A GN?!?!?!? umm...that one is mine, I knew I left it somewhere :D
anyway, good luck with the carfax!
CARFAX BRANDED TITLE CHECK
The Vehicle Identification Number submitted was checked against the CARFAX® branded title and odometer rollback database of over 100 million records. The results of this search are displayed below.
SECTION 1 VEHICLE SPECIFICATIONS
VIN: 1G4GJ1172HP460448
Year/Make: 1987 BUICK
Model: REGAL
Body Style: COUPE
Engine: 3.8L V6 SFI OHV TURBO
SECTION 2
BRANDED TITLE GUARANTEE
RESULT: ONE OR MORE BRANDED TITLES FOUND
Salvage Title NO branded title found
Junk Title NO branded title found
Rebuilt/Reconstructed Title NO branded title found
Flood Damage Title NO branded title found
Dismantled Title NO branded title found
Loss Due to Fire NO branded title found
Hail Damage NO branded title found
Canadian Total Loss NO branded registration found
Manufacturer Buyback (LEMON) NO branded title found
Exceeds Mechanical Limits Title BRANDED TITLE FOUND
Not Actual Mileage Title NO branded title found
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
07/02/1990 56,000 Virginia
Motor Vehicle Dept.
Moneta, VA
Title #43939440
EXCEEDS MECHANICAL LIMITS TITLE ISSUED
06/01/1994 Virginia
Motor Vehicle Dept.
Title #43939440
01/16/1998 59,138 Virginia
Motor Vehicle Dept.
Roanoke, VA
04/11/2001 26,840 Virginia
Motor Vehicle Dept.
Blacksburg, VA
12/21/2001 28,897 Virginia
Motor Vehicle Dept.
Abingdon, VA
New owner reported
10/09/2002 33,424 Virginia
Motor Vehicle Dept.
Vinton, VA
New owner reported
SECTION 3 ODOMETER ROLLBACK CHECK
RESULT: No odometer rollback detected in the CARFAX database.
Last reported odometer reading: 33,424 miles on 10/09/2002.
SECTION 4
VEHICLE HISTORY INFORMATION CHECK
RESULT: CARFAX has 6 database record(s) on this vehicle.
The full CARFAX database contains over 2.07 billion vehicle records which include title and registration activity, rental and lease usage, odometer readings from inspection stations, auto auctions and other sources. Run a full CARFAX Vehicle History Reportsm to obtain all the information in the CARFAX database on this vehicle.
WARRANTY DISCLAIMER
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THERE MAY BE OTHER POTENTIAL PROBLEMS WITH THIS VEHICLE THAT HAVE NOT BEEN REPORTED TO CARFAX. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
© 2003 CARFAX Inc., an R.L. Polk & Co. company. All rights reserved.
C35796102.May.2003 09:25:30
looks like either 13x,xxx miles or 23x,xxx miles..... 3k miles in 8 years is a stretch
ive got a 67 lark that went for nearly 20 years at 4 miles a year, ive got the inspection stubs, cars got 17k miles on it now.
Just assume 133K to be safe. :)
You should be able to tell with a close inspection.
Find out also if the timing chain has been replaced it is about that time for that car.
Subtract another $400-$500 if it hasn't been replaced.
Model: REGAL
Body Style: COUPE
SECTION 2
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Motor Vehicle Dept.
Moneta, VA
Title #43939440
06/01/1994 Virginia
Motor Vehicle Dept.
Title #43939440
Motor Vehicle Dept.
Roanoke, VA
Motor Vehicle Dept.
Blacksburg, VA
Motor Vehicle Dept.
Abingdon, VA
New owner reported
Motor Vehicle Dept.
Vinton, VA
New owner reported
SECTION 4
WARRANTY DISCLAIMER
Im close to Vinton, VA and saw a 87 around that you would prolly like some info on (there arent that many GNs around here). Email me so we can compare notes and if its the same car I have seen it in person and up close.
