T tsm3089 Member Joined Nov 11, 2006 Sep 27, 2015 #4 dank GN said: View attachment 263462 View attachment 263463 Click to expand... How is that sensor wired.
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Sep 27, 2015 #5 through your old MAF wires . I believe its 5V , signal, ground
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Sep 28, 2015 #6 12v, signal, and ground Bob
T tsm3089 Member Joined Nov 11, 2006 Sep 28, 2015 #7 gm 13577379 sensor i have left to right looking into the connector. ground 12 v signal
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Sep 28, 2015 #8 I don't have the pinout order handy, I was just posting to clarify that the sensors are 12v powered. Bob
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Sep 28, 2015 #9 OUT is the output signal that goes to the ECM's MAF input GND Ground Vcc is 12v ignition supply
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Sep 28, 2015 #10 Where can I order this sensor? How much is it? And a pigtail?
T tsm3089 Member Joined Nov 11, 2006 Sep 28, 2015 #11 sensor can be bought at summit amazon pace ect. $65.00 . pig tail from gm # 19301582 $ 21.00 You will need fittings if used in a braided line also.
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Sep 28, 2015 #12 These fittings will work for the ends right Aeromotive 15118
