first time to the track !
dentmasters01
Ok, I was kinda excited as this is the first time to the track with this car with the new build. I kept the boost low for now and hopefully after some tuning I'll turn it up. Hopefully going to Reynold's and turn it up to 25+ to see what she'll do. Here's how it went sat. night at 22lbs.
first pass
2.06 60'
8.02 @98mph
2nd pass
1.9 60'
7.52 @100mph
3rd pass
1.82 60'
7.28 @101mph
4th - 8th pass
1.80 -1.77 60'
7.11 7.12 7.13 7.13 7.14
101-102 mph
I've gotta get some better 60' going. Should have been in the 6.70-6.80 range with some good traction but all I had was street tires. :eek: couldn't leave at more than 7-8 lbs.
Its a cotton built 109 bottom end with eagle crank, oliver rods, roller cam. I've got some old stage 3 eastern performance heads, front mount, kb 70mm tb, gtq70 with a 3in. dp and a fast sys. I was a little disappointed because I just knew it was a 6 sec. ride the way it was. With some better 60'ers it was there. I never went over 22lbs. I may go back to the track this sat. night and see if I can launch it better.
7-8 lb launch with street tires ..... :eek: :eek:
I'm doing good to leave on 1 lb on street tires.
What kind of street tires do you have?
dentmasters01 said:
MT et streets. I have since launched at 15 lbs on the trans brake with a 1.63 60 ft. It spun. :mad:
ET Streets... that makes more sense.... I've gotten a best 60' of 1.81 so far with my ET Streets...on a stock car except for converter and DP... @ 12-13 psi boost... on a 10 psi launch
