Does anyone know of a source for the rubber wiring harness grommet that goes in the passenger side of the firewall and below the a/c box? Tried Caspers and Racetronix, but neither had it listed on their site...
The factory grommet is molded onto the wiring; it is not removable unless you cut it off.
When I build engine harnesses, I use a "stand-alone" style grommet that is the same size as the OEM part, but designed to feed wires through it.
