Boostmeister
- Sep 22, 2001
After putting the job off for like 2 years, I finally got around to replacing the power antenna. It really wasn't that bad a job. I want to summarize the procedure while it is still fresh in my mind.
1. Remove the battery to expose the "hole" in the fender.
2. Using a 7mm socket, remove the 2 screws holding the bezel that lines the louver hole in the inside of the fender. Remove the bezel while holding on to the inner duct.
3. Remove the inner duct by snaking it through the battery hole.
4. Remove the front knurled nut and screw that holds the fender louver vent.
5. Remove the antenna mast nut and plastic spacer. Tie a strong string to the cut-outs on the top of the antenna mast tube. Also tie a string to the antenna wiring connector.
6. Protect the door and fender with tape, then remove the bolt with star washer holding the antenna in place. Use a 10mm wrench.
7. Reach through the louver hole and guide the antenna, mast first, out through the battery hole. As the antenna reaches the hole, use a stubby phillips screwdriver to remove the 2 screws holding the antenna coax cable.
8. To install the rebult/new antenna, reverse the procedure, taking care not to tangle the coax and wiring while snaking back.
Its a little tricky, but overall not too hard of a job. I actually think its easier then a regular GN.
