Jim Blackwood
- Feb 25, 2007
I need just the cover and used is fine. No gears necessary but I would like the cover to be complete with relief valve, spring, etc if possible. If not I can use parts from other style covers that I have probably. Minor wear is not a big deal as I'm using a booster plate (TA).
The application is '82 Regal 2bbl. Anything that matches that is fine. It has an estimated angle of about 38 degrees from the fore/aft axis for the filter. I need it because the ones I have do not allow enough clearance for the filter in this application.
JB
JB
