Those should be OK.AC R42TS
No not necessarily , but every car is different and many like to run non-projected tip plugs on E85 & TR6 . These are a good , cheap & readily available option .Are you saying that the plugs I'm using could be causing KR?
Looks like a good plug. Same heat range as an R42 but its non-projected.Try these , non-projected tip , resistor , and cheap .
https://shop.advanceautoparts.com/p/ngk-nickel-spark-plug-br6fs-4323/12031657-P
NGK BR6FS aka NGK 4323
This is the plug I switched to after the non-resistor plug issues myself and others had a while back . No problems now .Looks like a good plug. Same heat range as an R42 but its non-projected.
I haven't yet, but will do this tomorrow.Did you get to fix the wide band ground? The wide band ground has to carry the amps for both the sensor controller and the sensor heater. Grounding it to the powerlogger block stands a good chance of overloading that circuit (through the powerlogger / ECM).
The ECM is grounded to the engine, so if you ground the wide band to the engine you should have near zero ground offset. The WB controller reading should then match well with it's analog output.
The low boost pulls are pretty rich. Might be "rich knock" like you were suspecting.Made a couple runs with the WG rod disconnected. One was clean the other had some KR. Still get 15-16 lbs of boost with it disconnected.
I richened it up to 11.3 today and made a couple pulls with very little KR. One thing that I notice is that it always seem to appear right at 4800 RPM. Could this be from some weird harmonic that the motor is creating with something that rattles?
It's not the one that can be calibrated. It's an AEM 34-3100???Does your wb require calibration? Maybe it's not reading accurately or needs replacing.
