T TD2593 Grumpy Joined Jan 19, 2002 May 14, 2004 #1 Does anyone know the part numbers for the Federal Mogal race bearings Rods and Mains in .010 Thanks
8 87GN_70GS Active Member Joined May 28, 2001 May 14, 2004 #2 Mains: 107M10, super duty alloy, 1/2 groove, performance main set 6-7120CH10, super duty alloy, increased length, perorfmance rod set The rod bearings will be a little bit wider than the standard (6-3755AP) bearings, 0.735" vs. 0.659" .
G getchasum MISSING 2 CYLINDERS??? Joined May 23, 2002 May 15, 2004 #3 Is there a pt# for a FM Main 3/4 grooved set? In the GMHTP build up Jack Merkel touches on a NEW one being produced, but does not list a pt# for it.
R Russ Merritt New Member Joined Aug 11, 2002 May 15, 2004 #4 Is it a new engine? Or just doing a main and rod bearing swap?
T TD2593 Grumpy Joined Jan 19, 2002 May 15, 2004 #5 This is a new motor, Ive used the those FM bearings before I really like the wider rod bearing.
