Motor has not been fired for several days, put the lap top on the ECU this morning before the engine was fired to make adjustments before hand. All tables are totally screwed up, the fuel table is all 200 straight across, spark is 63.8 straight across, AF table is 15.9 straight across. Nothing was changed to cause this. Disconnected from ECU, reconected samething. Loaded ECU back up with correct tune up, loaded fine all parameters, motor starts same as before but the wide band O2 will not talk with the ECU AF is 0.0 !! The guys as FAST have never heard of this before ??? All wiring is fine no connections have been shorted, battery charger was never on while ECU was powered, everything is OK with the wiring and motor. Whats up with this ??? The ECU seems to have lost its memory and now in need of recalibrating for my wide band O2 have you seen this before ?
