johnplogii
Senior citizen
- Aug 13, 2005
I counted along as I watched & came up with 7.0x? Probably should have used a stopwatch. Nice run Brian.
GN's only came with v-6's. i understand the haters.
By the read of most people, In 10 years this forum will be all Hybird...lol
8-12psi. Less is better. Hard to control it. If you leave high It ramps too fast and too little it's lazy. Less is better though. Using an External with a controller is a huge advantage with the ramp in. You can leave higher and ramp slower to not overwhelm it.
exactly. you may even need less than thatDang, I'm glad you said that. My coaching staff has been telling me to really launch it hard and I took them at their word Car went into the high 1.40's for 60' but was not near where it should have been in the first half of the track. Will start at the 8# level and see what works.
Thanks.
10;08 @142mph
Quik Six said:Dang, I'm glad you said that. My coaching staff has been telling me to really launch it hard and I took them at their word Car went into the high 1.40's for 60' but was not near where it should have been in the first half of the track. Will start at the 8# level and see what works.
Thanks.
All passes were better e.t. and slower mphso bison how does 10:08 @ 142 sound?? am i close? or are you just not going to say?
murphster said:I had a quick question on those A/F #s. Are you running two M10 nozzles, 1 M10 and 1 M15? Do you estimate your meth content at 20-25%? I made some lambda tables by meth content to try and get a better idea of what my target A/F should be for high 9s/140mph.
Not sure how to exactly calculate the meth%. Using the sprayed flow gives a very high meth% if you compare to the lb/hr from the injectors so you wouldn't use that # to look up the a/fs on the table. But making some quick guesses and comparing to experience/recommendations.... I'd say for a single nozzle in a car running in the mid 11s shooting for a gas a/f of 11.76-11.96 the 15% meth a/f range is 10.76-10.95. For the dual nozzle faster cars shooting for a gas a/f of 11.57-11.76 the corresponding a/fs for 20% meth would be 10.26-10.43. This corresponds to your posted 10.2-10.3 a/f on these runs.
The table is attached.
murphster said:Oh yeah, congrats on the runs. Only seems like there are a handful of people currently trying to get those #s on 93 and alky. My work has been busy but should be able to get some track time soon. Still working on some upgrades too. It never ends.
Also, a quick comment/question about the launches. Having the electronic boost controller combined with an ignition based 2 step, seems like lots of variables to play with. Lets say my converter likes 3800 on the launch..... I can set the 2 step rpm at 3800 and the launch boost at 8psi. To hit harder I can change the launch boost to 10psi. On the other hand I can increase the 2 step rpm to 3900 and keep the launch boost at 8psi to hit harder. I'm not an expert at this but it seems like once I find my sweet spot on the converter I can leave the 2 step rpm alone and just play with the launch boost setting to adjust for the track conditions. Haven't really used the 2 step rpm much but it does seem like it would you better control when combined with the electronic boost controller launch boost setting vs just using the electronic boost controller alone. Maybe someone has some comments on this.
BEATAV8 said:Curious... do you run a knock sensor? Or do you use other means (plug reading)?
On launching a car and getting the most typically you need the rpm to into the power band asap and then ramp the boost in to have more consistent 60' times. My engine isnt making dick for power at 4000/10psi. It's what happens after you start moving that will determine if the car is going to hook. It's hard to control the ramp in without electronics and really hone in the 60'. If you leave to low it will be lazy. Too hard it will spin. With electronics you can have variables on launch rpm/boost and still get decent results just about everytime launching.
