Flyin Brian
- Jun 18, 2011
Ok, I know this subject has been beat to death and I have searched the forum and found lots of information but I have intermittent false knock that is driving me crazy and I don't know what path to take. I can floor it off the line and get tons of knock retard (see below) sometimes and none other times. I am sure it is false knock as I can hammer it in third all day long and get no knock retard (see next image later in the same run).
I like the idea of having a knock detector for safety but tons of other people run without one and just watch the wideband or egt's and read the plugs and are fine. My plugs don't show any sign of detonation. The car runs terrible when it yanks out 15 degrees of timing for no reason. I am only running 18 psi boost and 23 degrees of timing on E85 so there should be no knock as rich as I am running it. I have gone through the checklist and checked or replaced almost everfything. I have a new knock sensor and it is not overtightened. Almost everything under the hood is new. The only thing that I have not replaced is the ESC module and the engine wiring harness. Any suggestions? Should I just run without the knock sensor? Any input would be greatly appreciated.
