blacknight80
- Dec 26, 2013
hey guys,
I've been working on this little side project for a little while now and I thought I would share with you. I used the idea I found on the forum to use a cutlass tach and gut it. I had a few extra instrument clusters laying around that I borrowed needles and clock delete faces from. I spent about 8-10 hours on Microsoft paint cutting and pasting numbers from a clock to ensure I had a perfect match. I scanned in the clock face in the highest resolution then zoomed way in and deleted pixels one by one. I used the R in Quartz for the R and P, I used the M from the temp gauge.
I used carb cleaner to take off the factory clear and 60 grit paper to knock of the delete plates hash marks. I followed the 60 grit with a scotch brite pad to get the brushed look back. I printed the graphic out on water slide paper and after about 10 failed attempts I got it. I kept having the decal pucker when I applied the clear to it. So i learnt to take my time and put one spittery coat on at a time. After I got a decent layer of clear coat on it I wet sanded it to smooth it out and I risked laying a heavy coat on and it worked.
I found that some of the clusters have shorter needles than others I am still playing around with the different lengths. I believe the fuel gauge, water temp and volt gauge have the longer needles.
All in I think it cost me 75 bucks.......my time isn't worth anything when I'm working on this car
$25 for the tach at a wrecker
$50 for a package of decal paper
I had the spare parts laying around so we will call them free.......I'm sure I over paid for them at one point but I won't count them.
I've also removed the v6 logo off a spare boost gauge and put the power six logo in its place but I wasn't happy withe outcome so I stripped it and am going to try again.
The next thing will be to check my stash to see if I have a spare full gauge bezel and paint it charcoal along with the radio bezel and dash bezel to mimic the 82 gn.
