Actually this is an 85 I bought off a guy and he had it sitting for a year and some change. So far I just changed the spark plugs, plug wires, fuel filter, oil change, had to change the internal rubber hose from the fuel pump to the inside of the tank. FYI the fuel pump is an aftermarket high output one, but I am not sure which brand. I have been through couple tanks of gas, and even threw in some seafoam. I am getting the right TPS voltages. And no I do not have a scan tool for my hotairs yet.
It is running a lot better than when I first got it, it just still has that stutter/surging at about 12 psi. It will run smooth and quick if I keep the boost at 10, but that is all I can take it up to before these problems arise. I currently have the fuel pressure at idle at about 44-45 psi, but I cant see what it does after 10 psi as per my previous explanation. It has some aftermarket chip in it, and according to the guy when he was driving it it was fast as hell.
I will probaly do the tranny filter change and rearend this weekend. The only thing I can think is increase fuel pressure or put a new pump in or check the injectors and possibly try a different chip. But I will wait for the fuel pressure gauge mounted on my windshield to see what it is actually doing. Thanks guys, and keep the suggestions coming.
