****Also make sure the torque convertor is unlocking if it is a lock up type convertor - a scan tool can help. If you have a 9 inch convertor, it may be causing your stalling problem due to rotational mass difference, and a chip change with anti-stall feature can help prevent the problem.
If you still have the stock convertor, check and make sure it locks and unlocks properly as your TCC solenoid may have or be going bad. It's a fairly common problem, and relatively easy to fix if this is what it is.
Good luck
Billy
Montgomery Village, MD
