Hi, I have a 87 gn and I'm having a idling problem at the light the check engine light has flash once or twice also at the light. My fuel gauge has moved around a few times but normally goes back to 43psi. This morning I let it warm up then when driving know problems as soon as I stopped at the light it rev up while I'm on the brake fuel pressure at 48psi. Like it wants to take off on its own. My tps is set at 44. I will say this when accelerating it bogs down tell the turbo kicks in with a puff of black smoke and when slowing down it bogs as if gas is still flowing. Also whats the best way to check for a vacuum leak?
