G gn dennis Member Joined Nov 8, 2014 Sep 7, 2019 #1 Does any one have one they like and where did they get it, and model number and brand? Thanks Dennis
B BuicksBad Ur favorite Drug Dealer Joined Apr 10, 2019 Sep 7, 2019 #2 This one is suppost to work but get a second opinion. Attachments 20190907_081504.jpg 1.9 MB · Views: 62
G gn dennis Member Joined Nov 8, 2014 Sep 7, 2019 #3 BuicksBad said: This one is suppost to work but get a second opinion. Click to expand... Thanks that helps alot
M mikestertwo Well-Known Member Joined Sep 13, 2006 Sep 7, 2019 #4 Just get one for a small block chevy
G gn dennis Member Joined Nov 8, 2014 Sep 7, 2019 #5 mikestertwo said: Just get one for a small block chevy Click to expand... Will that work on our Buicks? Where did you get it from? Thanks
M mikestertwo Well-Known Member Joined Sep 13, 2006 Sep 7, 2019 #6 Yes it will fit our engines. Mr. Gasket part# 3795G. JEGS carries them. I'm sure there are other part houses that carry it.
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Sep 7, 2019 #7 i use this one. cheap and it works https://www.summitracing.com/parts/...whsCG0_OC7Nh35yo7_Ft8Rq9bG9rAEg4aAjnKEALw_wcB
Turbo6inKY Short Guy TurboBuick.Com Supporter! Joined Jun 18, 2001 Sep 7, 2019 #8 gn dennis said: Will that work on our Buicks? Where did you get it from? Thanks Click to expand... Available at every single parts store in their loan-a-tool program.
michael evans Well-Known Member Joined Feb 27, 2008 Sep 12, 2019 #9 I just took a points distributor from a 455 and striped it down. Buick 350, 455 and 231 V6 all the same. Sure there is more that it could be used for.
G gn dennis Member Joined Nov 8, 2014 Sep 12, 2019 #10 michael evans said: I just took a points distributor from a 455 and striped it down. Buick 350, 455 and 231 V6 all the same. Sure there is more that it could be used for. Click to expand... I got one for the gm small block. Thanks Dennis
G gn dennis Member Joined Nov 8, 2014 Sep 14, 2019 #11 gn dennis said: I got one for the gm small block. Thanks Dennis Click to expand... Used this tool primed my engine worked great.
