$165. This set was built to display the various splice ends. All are properly terminated and sealed, ready to use in your restoration or repair project. Most of the connectors are here, some are not: Relay ends, Oil pressure switch connector, Fuse Links, Grounds, Starter solenoid terminal, and maybe one or two others. Everything you see is described as shown. Most of the 16 gage wires are white, some are black (female Weatherpacks) and a few connectors use color-codes wire. What you see is what you get, great deal for your wiring or re-wiring project.
