T
turbov6ta
Guest
i am at the end of my rope with tps! at 15 psi my car breaks up at about 3500-4000 rpms. i have replaced the coil and moduel, new 62 mm tb, new vac lines, boost acuator, new te 60 turbo , thdp, new 42 lbs injectors, reds 42 lb 100 oct chip,new wires, new plugs, new walbor 340 pump w/hot wire kit, new boost solenoid, new IAC. IF YOU HAVE HAD THIS PROBLEM PLEASE LET ME IF YOU HAVE FIGURED IT OUT.
