jpwalt1987
- Nov 9, 2003
I took my engine down for an inspection and refreshing after 3 years of hard use. I had a couple of oil leaks and figured what the hell nows a good time to do it.
I had decent oil pressure but it did seem to be a bit lower at cruise than usual. There was no noises to be heard.
This is what I found. The rod bearings looked like typical of a high HP motor. No copper showing but definitely worn.
The main were another story. I'll let the pictures tell the tale on them.
The crank looks like just a light polish will take care of it. All main journals were within .0002 of each other.
Check out the pictures of the cam bearings!! The front had the usual wear from the cam. The middle two were ate the f@&k up!! I have never seen a cam bearing get like this. It didnt hurt the billet roller cam though. This engine was professionally built by a well known builder. It has always had Valvoline VR1 10W30 in it with wix filters.
I also had 2 bushings in the wristpin gall up some and one appeared to be cracked a little.
Any ideas on why this happened? This is a pump gas and alky streetcar and I log every time I drive it with the powerlogger. The only tine knock ever shows up is when the tires are spinning. I keep a very close watch on the tune.
