I know there is a emssions forum, but it doesn't look like it gets much activity
I have a T with 72 lb injectors, MAF translator, and 206 roller cam.
need some advice if there is ANY way to get this through VA emissions.
my HC are way high against the 77 standard
some thoughts I had were buying the stock injectors, and an emissions chip
I do have a high flow cat, and could play with the MAF translator settings
so a few questions, is it even possible to get the car to run clean with the 72 lb injectors??
I tried mixing up some alchohol to lean it out some but the HC was way high!!
anybody got some good stock injectors and chip they can sell cheap or loan??
is it worth trying to change the MAF translator settings and possible to pass with 72 lb injectors??
thanks for any advice!
