Red Canyonero
- May 24, 2001
So after vacation, I come back, and was going to take the TTA for a spin with my friends. Never had any problems starting it, or electrically (other than FP relay popping apart).
I've been tuning it and was mainly worried about those issues... so I pop the key in, key on..nothing, key off... key back on... I get dash lights & fuel pump prime, go to start, nothing, no crank, no click, ALL power is cut, I mean everything, you open a door and no interior light, nada. I mess with the battery connections, still no power. I loosen and move the ground on the pass. head, still nothing. I throw another known good battery in there real quick, same situation.
I was fed up, wasn't in the mood for car work after my vacation, and quit for the day (after venting frustration by throwing a few tools for missing a sunny day of cruising with the T tops off).
I've been busy, haven't looked at anything with it, but on a whim, I open the door... BLINK.. I have interior lights, not dim at all, like everything was ok. Ummm, ok, get your keys. Key on, I have dash lit up & fuel pump prime. WTF ? Go to start, same situation as before... nothing, and it kills EVERYTHING again.
So, where do I start? Or does this sound familiar to anyone? I'm thinking I need to check my grounds, possibly the fusible links at the starter?
TIA
Brian Green
89 TTA
01 Jeep TJ
TIA
Brian Green
89 TTA
01 Jeep TJ
