Clay Thompson
- Feb 3, 2002
turbosam6, when you said the wide band was hooked up were you talking about a five-wire 02 sensor? If not could you elaborate?
It sounds like the standard O2 sensor could not even be classified as a rich/lean indicator if if was as far off as your comment seemed to imply.
Also, what are the max EGT you can get away with?
