87_TX_T-Type
- Dec 27, 2016
So I recently installed the TurboTweak chip which eliminates the need for the EGR. What I can't definitively determine is what to do with the associated vacuum lines. (The EGR has been pulled and blocked already.)
Right now I simply have a "jumper" vacuum line which links the vacuum block line to the "T" at the firewall.
View media item 300
I searched the forums, and the best bit of info I could find is to cap the line if there is A/C and/or cruise control, which I do.
Just want confirmation (or an explanation) to make sure the line should be plugged as opposed to jumped to the "T" at the firewall.
View media item 300
