Not sure. Just finished my turbo replacement after a long 6 months. The new stock turbo from bison maxes at about 25 psi. I'm unable to find my previous chip settings, so I'm starting from scratch. Since the swap and added boost, I have tickled the knock sensor a few times, but I haven't completely figured out the tune yet. Had a couple of setbacks now - had to replace o2 sensor, and now something's up with the PS pump or one of the lines. Spraying fluid everywhere. So, she's garaged until I get into the new house with a little room in the garage. If I remember correctly, I actually backed the timing out a little in order to run 22psi. From what I've read, you gain more power by adding boost pressure than advancing timing.
Anyhow, once I get the ps issue taken care of, and get the PL installed, things should move a little faster as I'll know what my IDC is. Once I get that done, I'll post up for you.
