Nick, do you offer an e85 conversion kit for our cars? I just switched to e85 and would like to change out my pump, sending unit, and lines,.................
With respect to the OP, I would agree that the DW301 pump will be a good choice for your build and e-85.
As far as a "conversion kit" for e-85 the parts need to be matched to the selected power level and how the car will be used?
The most important factor when converting to e-85 is the fuel supply must be more than adequate for the desired HP. The pump is only part of the supply system as wiring, connectors and plumbing must also be reliable and selected to do the job required.
An original pump hanger/sender is marginal at best when new, and after 25+ years it is not a good part to provide ample and reliable service for power upgrades and more HP? We made mods to them, but they still sometimes have issues.
The new China-built replacements are ok as a replacement unit, but they still have deficiencies like the original?
Over a year ago we decided to build a quality pump hanger/sender unit that provides enough fuel for 600 HP on gas or e-85. We have built a few units and tested them, but many changes have been made and we are in the final stages of having billet parts on order, and wiring improvements incorporated, as well as a reliable sender/float unit.
The versions will be either single or dual depending on using an interchangeable adapter piece of our design, and stock rubber lines or AN lines can be used depending on your fitting choice.
So to actually answer your question, yes we will have a conversion kit available for various HP levels, but they are not available yet as we are just starting production, and the new DW 400 pump will not be available until next month at the earliest.
We plan to offer an e-85 conversion kit with the pump/hanger/sender, lines, wiring, and even with a chip and injectors from TurboTweak if desired!
