kingots2004
- Nov 6, 2007
well just got my car back from getting the exhaust and fast installed plus my dyno tune. i was wondering how close you guys feel the numbers are. also let me say the guy that put the fast on didnt sell me the fast or build the motor. it was sherwood performance(randy westmoreland) that did the tune and it was on a dynojet dyno.he set it up with 30 percent load to simulate my heavy car(full weight car with astroroof and im 300 pounds plus ac and power everything with no aluminum parts) at 6000 rpm and 24lbs of boost it showed 723.89 hp:smile: .93.05 degrees f,29.63 in-hg,humidity at 30 percent,SAE:1.02.
combo:
250 cubes,champion aluminum heads,212 comp roller,76gtq,ams500,3.5 downpipe with 3.5 singleshot exhaust(thanks to qwick6),champion ported intake,presion doghouse with70mm throttle body,power plate,3000 stall,cottons frontmount intercooler,95lb injectors and fast from cal hartline,625 magnafuel pump with -8 lines on c16 turboblue racegas.
combo:
