24psi 17 degrees timing and 10.5a/f excuse me but that tune makes no fng sense. what moron told you to run that
i have a snow performance alky kit running 93 octane
It's a safe tune not a power tune as it's fat with no timing so it can run that psi.
I put my car on a dyno this weekend and was slightly disappointed with the numbers. At 24 lbs boost they were 309.4 hp @4793 and 422.7 ft/lbs @3803.the a/f is at 10.5 wot timming is set at 17.5 from 3000rpm
Is this typical for a Te 44 turbo?
His A/F ratio isn't all that rich for alky guys.
He could be running washer fluid like the kit mfg recommends.
What kind of Dyno, Mustang/Dynojet?
Was the Wideband sensor in a pipe or sniffing it?
What torque converter and if it's a L/U are you locking it?
It's a safe tune not a power tune as it's fat with no timing so it can run that psi. The answers above can give a bigger picture and that's still only so much since we're not in front of the car etc.
BTW, does the car pop at WOT in first gear ever?
