fullahotair
- Feb 26, 2002
Selling my Duttweiler Neck IC - $200 + shipping. Comes with a shroud, that is functional, although it is ripped at the bottom and epoxied to keep it together. IC is still in the car as you can tell in the pic. It work perfectly no issues with it - just going to a Cottons FMIC. If someone is interested, I'll remove the IC and take additional pics. If i remember correctly, there is a spot on the IC that rubbed the IC fan or something...doesn't affect functionality. I have had it to 24 psi and no issues. I also ported the neck on the IC as well for what marginal gain that nets you. Does not come with hoses.
IC brackets - both included - $50 shipped
Ford Powerstroke IC - I cut off the 3" inlet/outlet with the intent to modify, but opted to go another route. I still have the pipes if you want them. It will need cleaned out inside, as there is oil residue in it from its previous use...- $50 plus shipping.
Thanks,
Nate
Thanks,
Nate
